VeriStand
Windows DPI scaling fails and shrinks labview when VIs with VeriStand .NET controls are loaded
I'm here to repot a bug. Using LabVIEW on computer running Windows Vista or later where the display scaling is set to higher than 100% works OK until you load a VI (either directly or indirectly) that has a VeriStand .NET control on its front panel. After that LabVIEW shrinks down to 100% scaling and is almost unusable on high-DPI displays like a Surface Pro or 4k monitor.
I was going to post this on the LabVIEW forums but it only happens with .NET controls from the NI VeriStand SystemStorageUI assembly. Any other .NET control works fine.
Thanks!
Stephen B
Message 1 of 1
(4,122 Views)
