VeriStand
how to use Veristand 2011 embedded data logger
Hi everybody,
I am a veristand beginner. I try to do a HIL simulation using Veristand 2011 and NI PXI 1042.
I have already added my simulation model on the System Explorer and create my 3 DAQ devices.
Also, I have ran it properly into my PXI.
The next step is to save the simulation data in the log file and add alarms.
Currently,  I try using the embedded data logger.
However, I don't know how to configure this and retrieve the data after simulation.
How many data log file do I have to add?
How can I define the channel group settings ?
Do I develop something to acquire the data from the PXI or not after simulation ?
I would be grateful for any help or documentation.
Thanks you for your time.
Pilpil.
(5,929 Views)
Do you know how to use Veristand 2011embedded data logger now?I don't know how to set "Log cammand" and "Log trigger". Which channel can map with Log trigger?
(4,069 Views)
