VeriStand
Write Alarm Log to localhost PC
A quick question, maybe.  When running SDFs and stimulus profiles located on a different PC (i.e., over a network), how can I set the alarm log file path to be on the local host PC?  At the path entry box, instead of 'C:\Data\*.*'  ,  I'd like something like '<localhost>\Data\*.*' .
(5,057 Views)
Accepted by topic author KB_GenMtrs
To do that you need to setup a network share (i.e. "Download" folder) and use an UNC like "\\localhost\Downloads".
Regards
(5,039 Views)
It worked.  Thanks!
(4,843 Views)
