VeriStand
veristand crash
Hi
I am using Veristand 2014, PXI controller 8109 and when deploying my project I get this error
the project seems to be correctly deployed and running on PXI : what can be the issue ?
thanks to all
(4,959 Views)
OK problem solved: related somehow to network configuration
thanks
(4,937 Views)
Hey fmichelini,
Can you elaborate on your findings a bit further? If there is something that is causing VeriStand to crash this is definitely something that we want to investigate. I'd like to try and reproduce and understand the problem on my end so that we can address it. Its possible that others might run into the same problem as well!
Thank you,
Tim A.
(4,922 Views)
Hi
in my VS model I addressed on the local target (the PC) a Ethernet port that was not avilable: when deployed the model tried to address the port and caused the crash
thanks
(4,912 Views)
