VeriStand
XCP and CCP Master Add-On for NI VeriStand feedback.
I have recently upgraded my LV and VS to 2013 version. Also, I am using the latest version of ECUMC toolkit. I have installed all these softwares in a brand new PC, formatted my PXI(Remote system) and downloaded all the latest softwares on to it. I deployed my system def file successfully. Now, I can see my analogue signals showing up on veristand workspace(tru DAQ) but no signals from my ECU. I am using the API functionality in my labview code to read/write from ECU. I am using the same code and hardware which used to work fine with the old version of LV, VS and ECUMC toolkit. Do I need to make any other changes for it to work ?
Jackson
Message 111 of 118
(1,896 Views)
which version of ECUMC Toolkit do you have installed?
Message 112 of 118
(1,878 Views)
ver 2.3
Message 113 of 118
(1,874 Views)
can you describe excactly what you did. Did you run the ECUMC toolkit using CCP or XCP via LabVIEW 2012 on CAN(NICAN or XNET)? What failures have you seen? Can you post IO Trace Log Files and CCP/XCP Spy Log File?
Message 114 of 118
(1,868 Views)
VeriStand 2012 support via the ECUMC (CCP/XCP Add-on) will be released in the next version of ECUMC which is scheduled shortly. Please use VeriStand 2011 until then if you need CCP/XCP support.
Message 115 of 118
(1,859 Views)
jackson j which beta revision do you use. I suggest you call in at NI directly with your beta program contact to discuss this issue offline.
Message 116 of 118
(1,849 Views)
Hi Stephen,
I have installed  ECUMC 2.2.1 version and imported XCP and CCP Master Addon custom device to sysdef file.
I am using Veristand 2011 SP1 for testing ECU.
On the main page of custom Device I have done setting as shown below:
Under Communication Properties I have selected option "Use communication properties of database".
I have imported A2L file successfully and I am able to see parameters under measurement and Characteristics field.
We have total of 4 CAN ports out of which 3 are assigned for other CAN bus communications and 1 for Diagnostic.
At first intance I tried to use already assigned CAN port of Diagnostic to this custom device and its failed to read
parameters from ECU.
So later I freed one of the CAN port out of other 3 and assigned to this custom device.
After deploying the project I tried to read the parameters from ECU but it doesn't works.
Using on boolean control I tried to "connect" custom device with ECU but still connection status is 0 and error code displayed
was -301096.
So please guide me about the settings on main page of this custom device if anything is wrong.
If settings are correct let me what exactly could be the reason for this failure.
Thanks and Regards,
Nilesh
Message 117 of 118
(1,797 Views)
Hi Nilesh,
This forum thread was for support on the custom device when it was an online download. Since then, the custom device has graduated to a shipping feature of the ECU Measurement and Calibration toolkit. Since this is now a shipping National Instruments product, please create a support request as usual for NI products by visiting www.ni.com/support
Thanks!
Stephen B
Message 118 of 118
(1,788 Views)
