‎07-25-2017 01:13 AM
when i want install veristand engine on the RT target,the MAX tell me that it need following dependencies:
veristand engine needs multifuction DAQ 15.0.0
veristand engine needs analog output series15.0.0
‎09-06-2017 04:08 AM
Same issue for me !
Any answer from somebody ?
‎09-11-2017 09:35 AM
If you consult the ReadMe for VeriStand, you'll notice that required software includes NI-DAQmx 15.0 and NI-VISA 15.0 or later. You may also need additional drivers depending on what target you're deploying to or what hardware you're using (for example NI-RIO or NI-XNET).
You can find the download for the latest version of NI-DAQmx here: http://www.ni.com/download/ni-daqmx-17.1/6836/en/
Hopefully that helps!
‎09-12-2017 04:22 AM
Hi, I have reinstalled NIDAQmx 15.0 drivers and 15.5 also but nothing changed.
Then I decided to completely uninstall all the NI software installed and re-installed VeriStand and Instrument Drivers only (NIDAQmx 15.0) and it works ! 🙂
Maybe something was messed up cause the softwares were installed on different times and from different Developer Suites distributions.
Thanks for your suggestion 🙂
‎09-12-2017 04:25 AM
Sorry, I forgot:
I also tryed to format and reinstall the RT target (on PXI chassis) but didn't work. But after NI software uninstall and VeriStand re-installed, also the RT installation on PXI chassis worked 🙂
‎09-12-2017 10:21 AM
That is interesting that you needed a full reinstall to resolve the error, but I'm glad you got it up and running!
