VeriStand
multi chassis
I have two PXI chassis and each chassis has it's own embedded controller (target A and target B) and I'm not using reflective memory to sync real-time data between the two targets.  I've created real time sequence A to deploy to target A, and real time sequence B to deploy to target B.  Can I create a stimulus profile (host) that runs the two real time sequences in parallel on their corresponding targets?  I'm not finding the multi tasking capability in the stimulus profile that I see in the real time sequences.  If not, what is a work around?  TestStand maybe?
(5,689 Views)
Yeah use the sequence call group. Should run them all at the same time. Note that they won't start on each target at exactly the same time so if they need to... You will need the RT sequences to wait for some external signal before continuing.
Stephen B
(5,682 Views)
