VeriStand
reset all outputs to initial values
in our case, a VeriStand project is running on a RT machine with cRIO-I/O.
Is there a possibility to reset all outputs to the initial values while the project is running? (I don't want to restart the real-time system or deploy the project again because that consumes too much time.)
(7,389 Views)
hello, maybe you could run a real-time sequence or CSV file, or trigger a procedure to do that. In any of these cases you'll have to write some code to set all your output channels.
(7,375 Views)
Accepted by topic author TTRD
you can create an alarm which calls a reset procedure. The Alarm can be mapped on a Boolean Button on the Workspace. Or you can call a RT Sequenze to reset your values.
Best Regards,
Philip
(7,360 Views)
A button on the workspace sounds good. I think I will try to define a procedure. The only problem is that I have to reset about 100 variables. However, it seems as if I can generate the XML-code of the procedure from a FPGA config. I'll get back if I succeed or encounter a problem.
(7,339 Views)
Works fine. Thank you both for the tip. 🙂
(7,321 Views)
Nice 🙂
(7,315 Views)
