VeriStand
stop stimulus profile though procedure
Harris,
So the older stimulus profiles manipulate the channel successfully after being mutated to the newer version?
Can you please upload a older profile and I'll like to take a look at the xml behind it to see if something is different. I want to double check there isn't anything different that isn't being called. You can also access this by opening up the files with simple text editor like notepad++.
Thank you,
Kyle H
Kyle Hartley
Senior Embedded Software Engineer
Message 11 of 16
(3,249 Views)
Hi Kyle,
Yes, from what I remember, the older stimulus profiles work with the Generator Engine State properly. I will confirm again later today. Attached is a mutated profile as you requested. Thank you.
Message 12 of 16
(3,237 Views)
Yes, I confirmed that the mutated old stimulus profiles do affect the Generator Engine State. The new profiles do not.
Message 13 of 16
(3,225 Views)
Thanks for the confirmation. Is there any signal at all to indicate that a new profile is running, and is there a hook for me to tap into to stop it? From what I can tell, there isn't.... Thanks.
Message 14 of 16
(3,202 Views)
Harris,
That channel only exists for the legacy profiles it isn't used by the newer stimulus profiles. So that explains why they aren't updating. There isn't a replacement for it either. You'd have to create something yourself to recreate that functionality.
Kyle Hartley
Message 15 of 16
(3,202 Views)
I see. If there's no channel available, I don't see how I can access the running of the stimulus profiles. I guess I'll put this into the idea exchange forum for a future release.
Message 16 of 16
(3,174 Views)
