VirtualBench
Crash when click on wifi Icon
My Wifi has changed.  Usually use an Ipad to control my virtual bench.
I tried to run the app from the PC with USB connection and it runs fine.
If I click on the wifi icon so I can change those setting the application crashes and wants to send a log to NI.
Running Windows 10 with latest updates on a Microsoft Surfacebook.
Have downloaded and am running version 17 but does the same thing with version 16
Any ideas
(3,474 Views)
I'm sorry this is happening 😞
Would you attach any error logs you see in this folder on your Surfacebook?
C:\Users\___YOU___\AppData\Local\National Instruments\NI-VirtualBench
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,464 Views)
