VirtualBench
VirtualBench V16 and V17 Won't Load. Stuck on White Box?
Hello everyone,
I have an odd issue.  V16 and V17 of Virtualbench won't load with my VB-8012.
When I launch the app, it hangs on what appears to be a white dialog box.
The VBench unit works fine on my other PC.
Windows 10 Enterprise 64 bit. Stable + Reliable LabVIEW2017 (23-Bit) installation running fine. Been developing and running applications with no issue.
VBench is only thing giving me problems.
It is visible in NI-MAX. I issued RESETS and REBOOTs from the menu to ensure the unit wasn't in a weird state.
How would I go about troubleshooting this issue?
--DV
(3,300 Views)
At this point, you've done great troubleshooting, and I can think of a few more things to try:
  1. Create a process dump file for R&D to debug to understand and fix the problem.
  2. One way to make the VirtualBench application return to "out-of-the-box" behavior is to delete its local cache folder.
    C:\Users\___YOU___\AppData\Local\National Instruments\NI-VirtualBench
Please do item one first, post the process dump file, and then do item two. I want R&D to get that valuable "bad state" information 🙂
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,241 Views)
