VirtualBench
Initialization Error with VI
I am trying to generate custom signals with a mix of different known frequency signals along with uniform white noise,
but i got stuck at the initial stage, it is throwing an error as attached below.
(5,112 Views)
That error clearly states you are using an invalid device name, at least one your computer does not see.  Double check the name.  Verify it shows up in MAX.  Or use the control's drop down to pick the one that is connected.
(5,095 Views)
Thank you for the suggestions, I tried verifying it through NI MAX, there it is not showing any device name
I have connected it with
the USB cable, even I cross-checked with VB device, the same name I have used for VI also
Still, it is throwing an error.
(5,084 Views)
