VirtualBench
VB-8012 Upgradability Questions
Greetings,
I've gotten my hands on a VB-8012.  It is currently on firmware 1.0.1f0.  I've got a few questions:
1) What is the highest firmware version this device supports? I can see the levels here: https://www.ni.com/en-us/support/documentation/supplemental/17/virtualbench-firmware-release-notes.h...
2) How do I go about downloading the correct firmware version for an offline update?
The post here: https://forums.ni.com/t5/VirtualBench/Offline-update/td-p/3867053 indicates where and how to update, but the included link points to the Soft Front Panel download page instead of the firmware drivers.
For what it's worth, I've installed VirtualBench 19 to see if this would allow me to update the instruments firmware, but no success.
Thanks for the help
Thanks for the help
Message 1 of 13
(8,191 Views)
The highest firmware version for VirtualBench devices is 18.0.0f0.
I believe the direct firmware downloads were removed, and it looks like the site is redirecting to the closest match, which is the application download page.
When you tried to use VirtualBench 19 to upgrade the firmware, what steps did you take and what happened? Was the system connected to the Internet?
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 2 of 13
(8,116 Views)
With the VB-8012 connected to WiFi, and connected to the PC via USB.  The PC is connected to the internet.
I launch the VirtualBench software and select File>Search For Firmware Update.  "The result is an error message stating "Undable to reach the firmware update server. Verify your internet connection and try again." See attached images
If I run the VirtualBench (version 1.0.1.49152)  that is included on the VB-8012 and attempt the firmware update I get error: "An unexpected error occurred searching for a firmware update.  Try again later, or check ni.com for updates"
Message 3 of 13
(8,095 Views)
Ok thank you!
@DJ_001 wrote:
I launch the VirtualBench software and select File>Search For Firmware Update.  The result is an error message stating "Unable to reach the firmware update server. Verify your internet connection and try again."
When I spoke with a colleague about this problem, we were able to determine a work-around. I'll send you a direct message with next steps.
Joe Friedchicken
[ Linux ] [ macOS ]
Message 4 of 13
(8,028 Views)
Hi Joe Friedchicken,
I'm in the same boat as the other user.  I have two VB-8012s that I cannot upgrade the firmware on.  Can you please message me as well or make a public post?
Many thanks!
Message 5 of 13
(7,967 Views)
Sure! I sent you a DM.
Joe Friedchicken
[ Linux ] [ macOS ]
Message 6 of 13
(7,890 Views)
We use VB-8012 instruments at our college and are unable to obtain the upgrades.  What is the process?
Message 7 of 13
(7,220 Views)
It might be best to DM Joe Friedchicken
Message 8 of 13
(7,203 Views)
I have two VB-8012s that I cannot upgrade the firmware on. Can you please message me as well or make a public post? Thanks a lot
Message 9 of 13
(6,273 Views)
We have many VB-8012s needing firmware updates. Can you help us out with how this can be done?
Thanks.
Message 10 of 13
(5,313 Views)
