VirtualBench
virtual bench "system error" Sequence contains no matching element
We have a Virtual Bench that will not correctly connect. We get a pop up "System Error" and the text in the middle reads "Sequence Contains No matching element"
Message 1 of 17
(10,708 Views)
Can you share more information about your system?
  • What firmware version does your VirtualBench have?
  • Are you running the application from the drive on the device, or do you have it installed on your Windows PC, or are you using the iPad app?
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 2 of 17
(10,703 Views)
The Virtual Bench has the latest update (as of last week) of the firmware. We are running the application on the device.
Message 3 of 17
(10,699 Views)
Thanks 🙂
I have two requests -- please do them in this order.
  1. Attach the application preferences file:
    1. Open a file explorer
    2. In the address bar, enter this path (copy/paste can help):
      • XP: %USERPROFILE%\Local Settings\Application Data\National Instruments\NI-VirtualBench
      • Vista, 7, 8: %USERPROFILE%\AppData\Local\National Instruments\NI-VirtualBench
    3. Attach the file ni-virtualbench-preferences.vbconfig
  2. Try switching to Demo Mode after you receive the error:
Joe Friedchicken
[ Linux ] [ macOS ]
Message 4 of 17
(10,687 Views)
I can run in demo mode. Did you get the attachment? (via email)
Message 5 of 17
(10,651 Views)
Also, would it be possible to just re-image the whole drive on the VB?
Regards
Harry
Message 6 of 17
(10,647 Views)
No. You can either attach it to your next post, or you can send a personal message. The file can help us understand what might have confused the application so we can improve its behavior.
Yes. Use the reset button on the back. The application also uses information stored on the PC when it starts. If the problem is there, then resetting the device alone won't help.
NI VirtualBench Help :: Reset Button
http://zone.ni.com/reference/en-XX/help/371526A-01/vbhelp/wirelessbutton/
Joe Friedchicken
[ Linux ] [ macOS ]
Message 7 of 17
(10,626 Views)
We have had several VB's do this and resetting the bench takes care of it every time. The way we are using them in a large classroom, the B's will likely be connected to a different computer every day. Would that make a difference?
Harry
Message 8 of 17
(10,580 Views)
I don't know 😕
If all devices and hosts are the same, swapping benches would not cause this error. It's possible that one of the VirtualBench devices isn't using the newest firmware, or one of the host PCs has an older application installed on disk. A mismatched app and device should not cause this, but if it does, I would like to see it fixed for everyone.
I would really appreciate it if you could send the .vbconfig file once you notice this error again -- analyzing it is the next step for understanding the defect.
Joe Friedchicken
[ Linux ] [ macOS ]
Message 9 of 17
(10,576 Views)
ok, I will watch for it.
Message 10 of 17
(10,567 Views)
