VirtualBench
virtual bench "system error" Sequence contains no matching element
We have not had that particular error message show up any more. It disapperaed as quickly as it arose.
Now for a new question. : Is it possible to use the arbitrary waveform memory to output sequences on the digital ports? We can do it programatically, but that limits the bandwidth.
Regards
Harry
Message 11 of 17
(5,437 Views)
No. The arbitrary waveform generator can only output through the "FGEN" BNC connector.
Message 12 of 17
(5,427 Views)
Is there any way to get data out on the digital ports more quickly than uploading a sample at a time through the interface?
Message 13 of 17
(5,421 Views)
No, the Digital I/O port is implemented as static digital. It's a sample at a time; there's no hardware timing.
What are you trying to accomplish?
Message 14 of 17
(5,419 Views)
We are trying to have our students build a simple r/2r dac using that port as the digital source.
Message 15 of 17
(5,416 Views)
Hmm. Yeah, without hardware timing, you're limited to how quickly you can send new samples to the device. With a quick test of 'write new samples in a loop', I can get about 660 Hz with a VirtualBench on USB and about 440 Hz over wireless, although that's going to vary with a lot of factors (bus latency, processing latency on the host computer, etc). That still should be enough to demonstrate how a R/2R DAC functions, but the things you could do with a slow DAC are limited.
I've made a note of this use case for possible future product improvements. Thank you for the feedback!
Message 16 of 17
(5,386 Views)
Thanks. Let me know if we can help. We would be glad to beta it if need be, and we have been writing a lot of LabVIEW for vb.
Regards
Harry
Message 17 of 17
(5,382 Views)
