Volume License Manager and Automated Software Installation
Directory Structure
Paul, could you actually provide a screenshot of the contents of Disk 1 of the DevSuite DVD you are selecting as the source? Thanks.
Message 11 of 18
(10,023 Views)
Corbin,
Attached are screen shots of Disk1.
Paul
Message 12 of 18
(10,020 Views)
Accepted by pknight12133123123
In one of the first pictures you sent that showed the VLM source page, you were pointing to D:\NI\DevSuiteQ3_2008\Disk1 but the picture you sent me that showed the first layer of contents (folder that contained setup.exe, autorun.inf, etc) was located at D:\NI\DevSuiteQ3_2008\Disk1\DevSuiteQ3E-1 (E). Try selecting one directory deeper and enter D:\NI\DevSuiteQ3_2008\Disk1\DevSuiteQ3E-1 (E) as the source. When you select a valid directory, the Product Name will automatically populate.
Message 13 of 18
(10,017 Views)
Corbin,
That fixed the problem.
It created three setups, one for our Debug group, one for our Full group, and one for our Developers group.
When I install directly from the DVDs, as a Developer I get the chance to install LabWindows.  Do I need to create an
installer for LabWindows or does the developer group setup that I just created allows me to setup LabWindows.
Paul
Message 14 of 18
(10,015 Views)
As long as you bundle the second DevSuite DVD (the DVD that contains CVI) you should be able to install LabWindows/CVI from one VLI.
Message 15 of 18
(10,011 Views)
Corbin,
How do you bundle the second DVD?  The VLM does not ask for a second?
Paul
Message 16 of 18
(10,010 Views)
This KnowledgeBase article steps through how to bundle the DevSuite DVDs into one VLI.
Message 17 of 18
(10,005 Views)
I will give it a try.
Thanks for the help.
Message 18 of 18
(10,002 Views)
