Volume License Manager and Automated Software Installation
How to use the locale flag in NILicensingCmd.exe
Hello Everyone,
Hope all is well. I am trying to figure out what is the purpose and how to use the /locale flag in NILicensingCmd.exe. The documentation seems a bit confusing to me. I do not understand the argument <culture> it requires.
I was unable to find any usage examples. Any help would be much appreciated.
Thank you
(5,523 Views)
Accepted by theautomator7
theautomator7,
Thank you for bringing this to our attention. It appears that the description for this option in the Help is unfortunately outdated. There is no longer a "launchActivationWizard" command option. However, the /local command is only used for specifying a CultureInfo value. If one is specified in a non-silent activation command line, for a culture that NI License Manager supports, then the Licensing Wizard will be displayed with that locale. Currently supported CultureInfo values supported by NI License Manager are "en" for English, "de" for German, "fr" for French, "ja" for Japanese, "ko" for Korean and "zh-CN" for Simplified Chinese.
(5,484 Views)
Thank you for the clarification. When I run the following command:
"C:\Program Files (x86)\National Instruments\Shared\License Manager\NILicensingCmd.exe" /locale fr /activateall
The Activate Software window shows the content in English and not French. Am I missing something?
(5,448 Views)
My apologize for incomplete information before. The 2-letter locale only works for the command-line output itself. To change the locale for the Licensing Wizard from the command line you will need to use the region specific culture code (e.g. "fr-FR", case-insensitive). Supported options are: en-US, de-DE, fr-FR, ja-JP, ko-KR and zh-CN.
(5,430 Views)
Perfect. That worked. Thank you.
(5,405 Views)
