Volume License Manager and Automated Software Installation
VLM server software for 2023 or 2024 will not open after install. I get a generic error with no code.
That worked. We are up and running:
Tim
GHSP
Message 21 of 33
(1,185 Views)
The ticket that I had open with NI is:
Request #: 03521433
You can add what we did here to it and close it.
Thank you for your time and guidance with this issue.
Tim
GHSP
Message 22 of 33
(1,182 Views)
Thanks Tim.
Ramamoorthy V
Software Engineer
NI
Message 23 of 33
(1,179 Views)
OK this problem came back today. I went back to the SQL dll and the name had been changed back. I need a better solution to this. Other applications my need to run SQL. I did rename the dll and that fixed the problem again but this seem like a very bad solution.
Tim
GHSP
Message 24 of 33
(767 Views)
Hi Tim,
SQLite does not support installing the System.Data.SQLite DLL in the Global Assembly Cache (GAC).
SQLite Encryption Extension: System.Data.SQLite with SQLite Encryption Extension via NuGet
(Please refer the first point in the above link)
Can you please try using a different machine that does not have any software that installs this SQLite DLL in the GAC, and then run your VLM on that machine?
This should resolve the issue.
Ramamoorthy V
Message 25 of 33
(737 Views)
What are the minimum requirements for this server? I looked and I did not find anything for 2024 Q1. version of the VLM. Obviously the SQlite issue probably will not be in that list so I will assume that is a requirement. IT is asking me what I need to set up a different server. Is there other software that you cannot have on this server as we set this up?
Tim
GHSP
Message 26 of 33
(707 Views)
Hi Tim,
This is the download page for VLM.
Volume License Manager Download - NI
You can find the list of supported operating systems on this page.
Additionally, please ensure that no application on the new machine installs the System.Data.SQLite.dll in the GAC location.
For assistance with migrating the VLM server from the old machine to the new one, please contact one of our support engineers.
Ramamoorthy V
Message 27 of 33
(675 Views)
I found that page. I did not list the software that NI's software cannot exist with. I have also tried to contact your support engineers. They were less than helpful which is how I ended up here in the first place.
If your software will not exist with other software you need to list that on the requirements. I am going to have to update 200 computers because your software will not exist on this server. It is an NI problem not mine, but now I have to do all the work to fix your issue. Seems pretty typical for NI lately.
Tim
GHSP
Message 28 of 33
(669 Views)
Hi Tim,
  • No software should install the System.Data.SQLite.dll in the GAC, as this is not supported by SQLite. The other applications on your machine that are installing this DLL in the GAC should instead place it in their local application directory.
  • As a workaround to unblock you, we have suggested migrating the VLM server to a new machine. I’ve communicated your issue to our support team, and one of our engineers will be reaching out to assist you.
  • Additionally, you may want to contact the team responsible for the application installing this DLL in the GAC and request that they configure it to use the local application directory instead. This will help avoid conflicts and prevent issues for other software.
Ramamoorthy V
Message 29 of 33
(644 Views)
SQlite is installed by Microsoft:
Microsoft's Use of SQLite:
Microsoft uses SQLite in several products, including Windows (all supported versions), Office 365, and SharePoint, for lightweight data storage and management.
Microsoft.Data.Sqlite:
Microsoft provides the Microsoft.Data.Sqlite library, which is an ADO.NET provider that enables .NET developers to interact with SQLite databases.
Should I ask Microsoft to move their stuff so VLM should work? Seems silly to me.
Tim
GHSP
Message 30 of 33
(621 Views)
