Volume License Manager and Automated Software Installation
VLM server software for 2023 or 2024 will not open after install. I get a generic error with no code.
Hi Tim
Just to clarify, Microsoft itself doesn’t install the third-party System.Data.SQLite provider into the GAC in any of its products; they ship their own Microsoft.Data.Sqlite library via NuGet and deploy it privately with each app.
The only way you’d see System.Data.SQLite.dll in the GAC is if another vendor’s installer explicitly called out to gacutil.exe on your machine.
You’ll need to identify which other application is putting System.Data.SQLite into the GAC and ask that team to change their installer so it deploys the DLL locally instead. Once that’s done (or you move VLM to a clean machine), your VLM server should start without the generic error.
Thanks. I hope this would have cleared your doubts between Microsoft owned Microsoft.Data.Sqlite and third party provider for System.Data.SQLite.
Message 31 of 33
(509 Views)
OK it looks like the software that is using this is FactoryTalk by Allen Bradley. I thought it might be useful to you if you ever try fix the VLM software.
Tim
GHSP
Message 32 of 33
(504 Views)
As mentioned earlier SQLite itself mention that having system.data.sqlite in GAC location is not officially supported.
Source https://sqlite.org/see/doc/release/www/sds-nuget.wiki
Message 33 of 33
(483 Views)
