02-18-2025 02:47 PM
Great change to the links. The size, color and bordering makes them a lot easier to identify. Thank you for the changes.
03-18-2025 12:04 PM
The next meeting is nearly upon us: A week from Thursday!
This time our presentations will be by Laird Free and Stanislav Rumega
Laird will present on "The benefits of staying with a Framework"
Stanislav will present on "The fastest and most convenient way to communicate control data"
We look forward to seeing everyone on the 27th!
03-27-2025 11:40 PM - edited 03-28-2025 12:48 AM
The link to the today's presentation about my AccByIdx tool that helps to make the use of the Set/Get Control Values By Index functions (the fastest!) for cross-VI communication also much more robust and convenient:
https://1drv.ms/p/s!AlY8Hi3iZjCBibVlrXWq5RnwLKQEdg?e=OTjyLe
It is PowerPoint file but since it is hosted on Microsoft OneDrive, you don't need an MS Office license or PowerPoint itself or any viewer installed locally. You can view it right in a browser.
As for the code itself, as I said, making this app turned out to take much more effort and time than I had anticipated when I started creating it earlier this month due to numerous Labview's ... idiosyncrasies. I made the latest mods and bug fixes literally today. So I want to test and debug it some more before publishing it.
Oops, sorry, I forgot to tell you during the presentation: The tool handles gracefully not only deleting but also renaming of the controls for which you already created accessor VIs. It will rename the accessor VIs accordingly, with the new control name instead of the old control name as a part of its own name, save those VIs with the new names and replace the links to them in whatever VIs you already are calling them at that moment.
03-28-2025 12:12 AM - edited 03-28-2025 01:01 AM
Thank you, everybody, again!
Here is my LinkedIN:
https://www.linkedin.com/in/stanislav-rumega/
Please note that I am #OPENTOWORK ! So I would really appreciate any leads and/or references/mentions.
Stanislav
03-29-2025 02:20 AM
Remember the problem I was having with Ctrl-Z (Undo) during my presentation yesterday? Turns out it is a recently discovered Labview bug. Already confirmed but with not much hope for being fixed soon.🙄
04-01-2025 10:35 AM
For those in attendance in person and who have reached out to me via email, I just submitted the attendance sheet, so you should be able to submit for recertification points now!
