Webcast Wednesday Discussions
Webcast Wednesday Contest # 15
Q1. Programmatically create a 2D array in LabVIEW (With any data points) and amplify  just the diagonal data points by 2 and  display the result.
Q2. Create a table programmatically in LabVIEW with 4 columns and 10 rows with the column data as mentioned in the figure above.Then based on the row number specified by user, the corresponding Cos, Tan and Sqrt value should be displayed
Q3. Take an array with mixed positive and negative values and separate them programmatically into two different arrays.
Leave your answers as comments below by clicking on Reply
You will need to be logged-in to do so. Click here to sign-in/sign-up.
Rules & Guidelines
  • Post your answers as comments on this thread.
  • The participant answering all the questions correctly and in the shortest time will be the winner. In case of VI or code as answers, the participant will also be judged on the basis of the efficiency of the VI/code.
  • The deadline for answer submission is next Monday. Entries made after Monday will not be accepted.
  • Entries made after the deadline will not be accepted.
  • The winner will be announced in the next session of Webcast Wednesday and on this thread, with further information & next steps.
Recordings of the Previous Sessions
Previous Contests of the Week
Message 1 of 34
(13,090 Views)
Check attached VI.
Answers are in separate tabs according to the requirements.
Q2 was not very clear. It states that the generated array should have 4 colums x 10 rows then the user should select the row number (which contains 4 elements) to display the results in the table that contains 10 rows. I believe there is some kind of typo so the user should select the column (which has 10 elements) then it would make sense.
Message 2 of 34
(6,676 Views)
Check attached VI.
Message 3 of 34
(6,676 Views)
Find attached VI.
Prashant Patel
PBP
Labview 6.1 - 2019
Message 4 of 34
(6,676 Views)
Kindly check attached VI.
In my previous answer I forgot to answer Q.3... This is updated one...
Thanks & regards
Sagar Doshi.
Message 5 of 34
(6,676 Views)
Message 6 of 34
(6,676 Views)
Kindly find attached the Zip file of "Contest 15".
Main.vi - (LabVIEW v2011 -Still don't have 2012 )
# Implemented using State Machines.
# Description and Tips are displayed for all Controls and Indicators.
# Some Guidelines are displayed for the user to know how to successfully implement each Test (Question).
>> Each Question is displayed in a Tab page + "Exit" (the Last Tab) will Terminate the program automatically on Click!
Thanks and Best Regards,
Ahmed Zahran
Message 7 of 34
(6,676 Views)
Hi
Find in LV2011
PBP
Labview 6.1 - 2019
Message 8 of 34
(6,676 Views)
Hi friends,
            I`ve made the VI, Please find the attachment is in LV. Your Feedbacks are much awaited. The version is LV2011.
Happy Independence Day, my dear friends....
Message 9 of 34
(6,676 Views)
Hi AmmouriPBPsagardoshiManxAhmed_Zahran all your works are great all the best guys......
Message 10 of 34
(6,676 Views)
