08-07-2013
05:29 AM
- last edited on
08-08-2024
10:31 AM
by
Content Cleaner
Question)
Create a Calculator in LabVIEW based on the the operations learnt today. For example, include - Basic arithmetic, compound arithmetic, Trigonometric operations, Matrix operations, Polynomial equation solving.
Points will be given based on functionality, aesthetics and programming practises.
Hint - Try using state machine with event structures. ( https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat... , https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html )
Leave your answers as comments below by clicking on Reply
You will need to be logged-in to do so. Click here to sign-in/sign-up.
Rules & Guidelines
08-08-2013 05:51 AM
Find calculator...
Give suggestions and feedback.
Regards
08-10-2013 04:22 AM
Hello Friends,
Please go through the attached file.
Please give feedback and suggestion.
Warm Regards,
Parth Somaiya
08-10-2013 11:05 AM
Please find my attached Vi for calculator
08-12-2013 03:33 AM
Hi friends,
I`ve attached my piece of work with this post. I hope there are lot of things that can be improvised from my VI from your feedbacks. To he honest, before I start building an calculator I was looking some sample calculator made this. All the best for the participants.![]()
08-12-2013 03:36 AM
Hi sapsatin,
Your calculator is great all the best for the contest.....![]()
08-12-2013 03:38 AM
Hi PBP,
Nice work, is that an JKI package that you have used in the program, to look simple... All the best ![]()
08-12-2013 03:43 AM
Hi Paarth,
The calculator is great and the run time menu
... All the best...![]()
08-12-2013 04:41 AM
@Ganesh,
No I haven't used JKI frame work. This is a standard frame work that I use in all my code developments.
Thanks All the best.
08-12-2013 05:53 AM
Hello Friends,
Please find the attached .rar file & run the Calculator.vi.
Give feedback & suggestions.
Thanks & Regards,
Shweta Walanj
