Webcast Wednesday Discussions
Webcast Wednesday Contest # 14
Question)
Create a Calculator in LabVIEW based on the the operations learnt today. For example, include - Basic arithmetic,  compound arithmetic, Trigonometric operations, Matrix operations, Polynomial equation solving.
Points will be given based on functionality, aesthetics and programming practises.
Hint - Try using state machine with event structures.  ( https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat... , https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html  )
Leave your answers as comments below by clicking on Reply
https://decibel.ni.com/content/servlet/JiveServlet/downloadImage/2-52994-89899/321ylper.JPG
You will need to be logged-in to do so. Click here to sign-in/sign-up.
Rules & Guidelines
  • Post your answers as comments on this thread.
  • The participant answering all the questions correctly and in the shortest time will be the winner. In case of VI or code as answers, the participant will also be judged on the basis of the efficiency of the VI/code.
  • The deadline for answer submission is next Monday. Entries made after Monday will not be accepted.
  • Entries made after the deadline will not be accepted.
  • The winner will be announced in the next session of Webcast Wednesday and on this thread, with further information & next steps.
Recordings of the Previous Sessions
Previous Contests of the Week
Message 1 of 39
(13,015 Views)
Find calculator...
Give suggestions and feedback.
Regards
PBP
Labview 6.1 - 2019
Message 2 of 39
(5,889 Views)
Hello Friends,
Please go through the attached file.
Please give feedback and suggestion.
Warm Regards,
Parth Somaiya
Message 3 of 39
(5,889 Views)
Please find my attached Vi for calculator
Message 4 of 39
(5,889 Views)
Hi friends,
              I`ve attached my piece of work with this post. I hope there are lot of things that can be improvised from my VI from your feedbacks. To he honest, before I start building an calculator I was looking some sample calculator made this. All the best for the participants.
Message 5 of 39
(5,889 Views)
Hi sapsatin,
               Your calculator is great all the best for the contest.....
Message 6 of 39
(5,889 Views)
Hi PBP,
          Nice work, is that an JKI package that you have used in the program, to look simple... All the best
Message 7 of 39
(5,889 Views)
Hi Paarth,
             The calculator is great and the run time menu ... All the best...
Message 8 of 39
(5,889 Views)
@Ganesh,
No I haven't used JKI frame work. This is a standard frame work that I use in all my code developments.
Thanks All the best.
PBP
Labview 6.1 - 2019
Message 9 of 39
(5,889 Views)
Hello Friends,
Please find the attached .rar file & run the Calculator.vi.
Give feedback & suggestions.
Thanks & Regards,
Shweta Walanj
Message 10 of 39
(5,889 Views)
