Webcast Wednesday Discussions
Webcast Wednesday Contest # 24
Question) Create a LabVIEW VI which has a UI similar to attached image.
The user will have to enter his details in the left panel and submit the information. The application should wait for the user to press submit information button.
Then the user should be issued a registration number which should be displayed in the display box below the submit information button.  His details along with the generated registration number should then be displayed in a table like the one on the right hand side in the attached image.
User event: If the user enters details such that the email ID has been already used then the display box should display an error and should allow the user to change the details and submit again. There can be various ways of implementing this simple code and are welcome but this is focused to be a learning exercise to understand USER events. Therefore it is mandatory that user event be implemented for the submission to be considered for contest.
You can implement various other functionality to make the application more realistic. For example, reading/saving data from/to a file.
Leave your answers as comments below by clicking on Reply
You will need to be logged-in to do so. Click here to sign-in/sign-up.
Rules & Guidelines
  • Post your answers as comments on this thread.
  • The participant answering all the questions correctly and in the shortest time will be the winner. In case of VI or code as answers, the participant will also be judged on the basis of the efficiency of the VI/code.
  • The deadline for answer submission is Monday.
  • Entries made after the deadline will not be accepted.
  • The winner will be announced in the next session of Webcast Wednesday and on this thread, with further information & next steps.
Recordings of the Previous Sessions
Previous Contests of the Week
Message 1 of 1
(3,689 Views)
