 wcchung33a
			wcchung33a
			11-16-2014 10:22 PM
Hi all,
i am working on project which need to send string message from WSN 3230 to PC. I know i can use a share variable but i want to try custom radio Messages to send string data. How can i make a custom one?
Andy
Solved! Go to Solution.
 KHartley
			KHartley
			11-17-2014 12:40 PM
Hey Andy,
Here is white paper that covers what you are asking for. You need the LabVIEW Wireless Sensor Network Module to impelement sending custom messages back from the node.
http://www.ni.com/white-paper/9116/en/
11-17-2014 07:52 PM
Hi Kyle,
Thanks for your reply, the white paper is good but it only show how to create user defind variable. I installed the Labview 2013 wireless sensor module and NI-WSN 1.5. When i drag the radio messages from WSN, it only have 5 options. How can i edit the radio messages and make it receive data just like the write paper example.
Andy
 abh
			abh
			11-17-2014 10:23 PM
To remove the rest of the options you can right click on that which you don't want and they will be removed and the option which is in white paper will resemble the which u gonna use.
thanks
