Wireless Sensor Networks
LEF algorithm - help
I am a computer science student and in college I got a project on routing algorithm in wireless sensor networks. The algorithm I have to deal with is called LEF (Localized energy-aware flooding). Unfortunately, I can't find articles and information about it anywhere. Only chatgpt knows something about it but I am not sure to the reliability of the information. I am counting on help.
(1,919 Views)
LEF is tricky to find because it’s not as widely published as other protocols. From what I understand, it’s a variation on flooding that tries to save energy by making decisions locally at each node. Instead of blindly rebroadcasting everything, nodes use simple rules to decide whether forwarding a message will help reach new nodes or just waste energy. That’s where the “localized energy-aware” part comes in.
The basic idea is that each node keeps track of its neighbors and the energy cost of sending messages. When a packet arrives, the node evaluates if sending it on will meaningfully increase coverage without draining too much power. If yes, it forwards; if not, it holds off. This reduces redundant transmissions and extends network life.
You might not find formal papers because sometimes LEF shows up in reports or conference slides tied to specific labs. Try searching for localized flooding with energy metrics in wireless sensor networks. Also look at concepts like controlled flooding, energy-aware routing, and neighbor coverage protocols. They share similar goals. If you have specific parts of the algorithm you’re stuck on, tell me and I can explain those too.
(781 Views)
It's been two years, but thanks for the reply. I managed to get the project done.
(770 Views)
