Wireless Sensor Networks
Selecting the input voltage on a wsn-3226 ?
Hi everybody,
I own several wsn-3226 that are mostly deployed on bridges for SHM applications. I was asked to add a pyranometer on one of them. The output of a pyranometer is pretty low and average about 0.2V. If I connect that on a wsn-3226, the 10V range will probably cuts a lot on the precision of the sensor.
I know that the wsn-3202 have a selectable range, but since I already have a couple channels available on my 3226 and even a couple spare 3226, I wonder if there is a way to reduce the input range on a wsn-3226.
Thank you
Mathieu
(6,482 Views)
Hi Mathieu,
There is not a way to change the input range for the NI WSN-3226. For a reduced range you would need to use the NI WSN-3202. You could try using something like an op amp to boost the signal before you input into the AI of the 3226. The Sensor power output on the 3226 can supply 50mA @ 12V. So you could use that as a supply for an op amp.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Network DAQ/Academic
(6,479 Views)
Thank you Brian,
I never used an op amp before. But I think that I will give it a try, it could be useful for other applications. Do you recommend a particular model that you know is working well ?
Thanks again
Mathieu
(6,473 Views)
