Hello!
I have recently updated my gateway 9792 software to WSN 1.4 from here.Presently I'm facing issues, in adding multiple WSN Nodes (3202/3226/3212) to my gateway and I can connect only to a single node. MAX version 5.3.3
I'm develop VIs & receive data from that particular node which is connected.
I found is that my system is missing NI WSN 1.4.0 API, when tried to reset software to 1.3 version.
Incase, If you need any error log file to be attached to trobulesheet issue, Let me know
Thank you.
PHANI
