Wireless Sensor Networks
generate zigbee signal
Hi everyone!
I have to generate the signal that zigbee understands with labview and by the moment I' generated an CW signal O-QPSK modulated. My question is how can I write a specific digital signal in labview? I supose that I have to create a package or a container with the correct information but I don't know how to do that. Anyone could help me? Where could I get more information??
Thanks.
(6,925 Views)
Hi
Have you succeded? I am too trying to use FPGA with the DIO to drive a Zigbee transmiter.
(6,519 Views)
Can you share the code you already have?
This way I can help you and tell you where which code should be.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,497 Views)
