Wireless Sensor Networks
WSN 3202 lost signal
Good morning engineers,
I have a WSN 9791 and a WSN 3202, I created a pogram, that is funcional. But when lost the wireless signal, I want activate one light, to alert which lost signal. There anyway form to resolve this situation?
Regards
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
(6,007 Views)
Thank you for posting your question on National Instruments' forums.
I'm not sure that I understood your problem.
If I'm right, you want to turn a LED on when you loose the connection between your 9791 and your 3202.
Am I right ?
Or do you want to check the connection status between the 9791 and the host computer ?
As there is no LED you can program on the 9791, I guess you wan to power a software LED on your host computer. Is that so ?
If you could answer these questions and be a little more precise about what you want to realize, it will be easier for me to help you.
Guillaume H.
National Instruments France
(6,002 Views)
Your question:
"If I'm right, you want to turn a LED on when you loose the connection between your 9791 and your 3202.
 Am I right ?"
You are right.
On the program can connect a LED when it loses signal. But like turning a light signal and noise, when this signal loss.
Regards.
Hugo Santos
(6,000 Views)
