Wireless Sensor Networks
received wsn 3212 without drivers and program
I purchased NI WSN 3212 data logger which I have just received. It does not have drivers and program. Assist me to get drivers and program so that I can do data acquisition and analysis.
(6,044 Views)
The NI-WSN Drivers are typically included with your WSN Gateway or starter kit, but if you need to you can download them here:
NI-WSN Drivers and Updates
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/WSN/
Once you've installed that, you should be able to find the WSN examples in NI Example Finder (LabVIEW Help >> Find Examples) under Hardware Input and Output >> NI-WSN.  Additional examples and getting started information can be found here:
Wireless Sensor Network (WSN) Setup and Services
http://www.ni.com/wsn/setup/
Tom L.
(6,031 Views)
