Wireless Sensor Networks
movement/ positioning sensors
Hello All,
Does any one know what kind of sensor senses the location or placement of an object? E.g. if the sensor is placed on 4 connected walls, and one of the walls is moved from its placed. I want
i sensor that can sense the position of the moved wall relative to the other walls. What sensor can do that? Any ideas please
(6,369 Views)
You could probably use an IR sensor to measure displacement like the one I list below and an NI WSN-3226 Voltage Node from our Wireless Sensor Network product line. See the links below for more information.
NI WSN-3226 4 Ch, 20-Bit, Programmable Voltage/RTD Combination Node
https://www.ni.com/en-us/support/model.wsn-3226.html
NI WSN-3226 User Guide and Specifications
https://www.ni.com/docs/en-US/bundle/373007b/resource/373007b.pdf
IR Sensor
http://info.hobbyengineering.com/specs/SHARP-GP2D02.pdf
Best,
Patricia B.
Applications Engineer
(6,357 Views)
