 demmy
			demmy
			04-13-2011 09:14 AM
Hello All,
Does any one know what kind of sensor senses the location or placement of an object? E.g. if the sensor is placed on 4 connected walls, and one of the walls is moved from its placed. I want
i sensor that can sense the position of the moved wall relative to the other walls. What sensor can do that? Any ideas please
		04-14-2011
		06:32 PM
 - last edited on
		10-25-2024
		10:12 AM
 by
		 Content Cleaner
			Content Cleaner
You could probably use an IR sensor to measure displacement like the one I list below and an NI WSN-3226 Voltage Node from our Wireless Sensor Network product line. See the links below for more information.
NI WSN-3226 4 Ch, 20-Bit, Programmable Voltage/RTD Combination Node
https://www.ni.com/en-us/support/model.wsn-3226.html
NI WSN-3226 User Guide and Specifications
https://www.ni.com/docs/en-US/bundle/373007b/resource/373007b.pdf
IR Sensor
http://info.hobbyengineering.com/specs/SHARP-GP2D02.pdf
Best,
Patricia B.
