Wireless Sensor Networks
Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem : communication with sensor
I flashed a MicaZ mote with an embedded web server smews
Now I want to test the web page.
I use a MIB510 program board and serial port.
I tried  with linux system by using this two commandes :
$slattach -s 115200 -p slip /dev/ttyUSB0 -L &
$ifconfig sl0 192.168.1.5 pointopoint 192.168.1.8 mtu 1500
I tested with Win xp by creating a new connection but I have the same issue.
Could you help on this.
Thank you.
(9,539 Views)
(9,535 Views)
J'ai essayƩ de poster dans les deux langues
(9,531 Views)
med_alpa,
You've commented on what you're doing, but what are your questions?
(I will reply more to your other post.)
Kevin S.
Message Edited by Kevin_S on 04-12-2010 10:15 AM
(9,512 Views)
yes my question is not clear, because I don't know the reason of the problem.
My problem is : I can't acces to the web page embedded in the MicaZ sensor (the web server is not responding).
ok My questions are :
1) How to verify if it's related to the sensor or the serial line?
2) Is there any stepsto do : should I flash sensor keeping the switch off or on?
3) when I test, should I keep the switch on the mib510 turned ON or off?
4) Is there any additional commands to run before accessing the web page (slattach and ifconfig)
Thank you.
(9,507 Views)
med_alpa,
National Instruments does not make the MicaZ node.  I would recommend asking on the Crossbow forums.
Kevin S.
(9,495 Views)
Thank you for the link
(9,491 Views)
