luc desruelle's Blogue
Navigateur communautaire
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Desruelle_luc
6174 Visites
3 Commentaires
De l'aide sous LabVIEW? Lorsqu'un développeur débute, il est normal qu'il se pose de nombreuses questions et qu'il ait besoin d'aide. S'il est seul, comme c'est souvent le cas, il peut rapidement se trouver dans une impasse et perdre beaucoup de temps. Il est très important de connaître les bonnes méthodologies à appliquer pour trouver les bonnes réponses.
Lire plus...
Desruelle_luc
7405 Visites
1 Commentaire
The survival of the fittest applied to the LabVIEW Dataflow model...
PS : You can download the presentation  Darwin applied to LabVIEW V2.2.pdf attachment and LabVIEW examples code.
Recently, I made a new presentation (LabVIEW User group LUGE) "Darwin applied to LabVIEW: the evolution of the data management." subtitle “The survival of the fittest applied to the LabVIEW Dataflow model ”.
With deep humor this presentation makes the link between the evolution of the LabVIEW data and the Darwin's Theory of Evolution.
The presentation deals with the evolution of the concept of "Data communication" of the LabVIEW dataflow model:
lDataflow element to Variable Interfaces, to Buffer Interfaces
lTo store a value in memory/ To access the value
lTo prevent Race Condition, buffer copies
The presentation does answer the following questions:
lWhy avoiding local, global, Property Node? How to avoid Race Conditions? Does FGV prevents Race Condition (realy!) ?
lWhich method to use? Why?
lWho is the survival of the fittest? (the survival of the most scalable)
  • LabVIEW follows a dataflow model
  • In dataflow programming, you generally do not use variables. For a literal implementation of this model.
  • Dataflow models describe nodes as:
      • consuming data inputs,
      • producing data outputs.
  • Advanced concepts : LabVIEW contains many data communication methods.
  • For example, local and global variables are not inherently part of the LabVIEW dataflow execution model.
  • LabVIEW contains many data communicationmethods, each suited for a certain use case.
  • Can by order into 3 types:
lDataflow elements, the primary methods
lVariable Interfaces
lBuffer Interfaces
For diner tonight: Functional Global variable (FGV, LV2), Action Engine (AE), DVR, OOP, State Machine and QMH. Speed demonstration, UI thread, memory management (buffer copies) and Race Condition with simple and downloadable examples.
source: https://www.ni.com/docs/en-US/bundle/labview/page/data-communication-methods-in-labview.html
for example, (CLAD exam): Which of the following is the best method to update an indicator on the front panel? And explain WHY please!!!
  1. Use a Local variable
  2. Wire directly to the indicator « Data Out »
  3. Use an implicit « value » property node
  4. Use an explicit « value » property node (reference)
A+
Luc Desruelle | avatar_ld.gif| Voir le profil LinkedIn de Luc DesruelleVoir mon profil | Mon blog LabVIEW
CLA : Certified LabVIEW Architect / Certifié Architecte LabVIEW
Co-auteur livre LabVIEW : Programmation et applications
LabVIEW Champion
Contact
Tout télécharger
