LabVIEW Interface for Arduino Discussions
Autodetect and Init VIs requested by Nathan
Hello Nathan,
Attached is a zip file containing the two zip files you requested,.
Howard
(3,608 Views)
.7z extension is used by 7zip.  It is one of the best file compresion tools available and it is free.  See:
<http://www.7-zip.org/download.htm>
And yes you are right I should have uploaded each file.
Thanks for the tip about using the "Advanceed Editor".
hrh1818
(3,081 Views)
I know about the program, I don't use it by choice.  I will always use .zip archives on public forums becuase it is the most widely used and natively supported archive.
(3,081 Views)
