AR Drone Toolkit for LabVIEW - LVH
Video stream ARdrone2 Labview
Hi ,
l just downloaded the modifed ardrone toolkit that will enable us to show video stream of ardrone 2 through labview
it works finebut the problem l don't know how to convert "picture" type to image so that l can process it using IMAQ functions.
Any one knows about this?
l need it for my project
Your help is appreciated
My pleasure
Message 1 of 12
(18,833 Views)
Hi.
I have used this, so it should work
Convert LabVIEW Image Data to IMAQ Image
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
Message 2 of 12
(15,509 Views)
Hi sir can check the VI l attached your VI to the one l have but l saw only video stream pictures not the images that should be converted.
can you check the code?
l want to see the video stream in terms of images not pictures.
l'm sorry because l'm new to labview vision tools.l need Your help at this point and l can proceed easilly once l have the images appear in the screen like a video
l will not forget your help
My pleasure
Message 3 of 12
(15,509 Views)
Hi Again.
Have a look at the attached code. I used the VI I linked to in my previus post, and the example called "AR Drone - Simple Video" from the Example Finder.
Attached code is in LabVIEW2013.
Best Regards
Alex E. Munkhaus
System Engineer
Message 4 of 12
(15,509 Views)
Thank you sir l will check it now
Message 5 of 12
(15,509 Views)
Hi sir r u using the ARDrone toolkit the orginal one or the modified one ?
becuase l ran now but l didn't see any image.
Message 6 of 12
(15,509 Views)
For me l'm using the modfied toolkit that will stream the video as pictures.
Message 7 of 12
(15,509 Views)
Hi sir l didn't get any images l have a white screen but when l run the original video stream through the modified toolkit l see the video stream.
May you help me,please?
because l need it to my final project
Thank you in advance for your help
Message 8 of 12
(15,509 Views)
Hi sir l modified the code until it works but l have a delay of around 5 seconds
Is this normal or there is a way to reduce the delay?
l noticed that the additional blocks make this delay compared to the original VI that comes with the toolkit which is good with small delay that is not significant
Thank you for your help
Message 9 of 12
(15,509 Views)
Hi DroneLover22,
i've this problem "error 1097 occured at call library function node..". I didn't get any image, but when i run only original video stream it's all right.
Are you able to help me?
Message 10 of 12
(15,509 Views)
