Academic Hardware Products (myDAQ, myRIO)
Controlling SERVOS Using myDAQ and LabVIEW???
We currently want to use the myDAQ using LabVIEW to control multiple (5) 7.4V servos. However we are not sure where to start. I know this is a bit vague but any help will be appreciated. Many thanks.
-bbzc
(4,392 Views)
You will need to provide power to the servos from a power supply, but then you should be able to use a PWM output on the myDAQ to control them.
There's an example here: https://decibel.ni.com/content/docs/DOC-19953
It's also worth Googling 'mydaq servo', as it returns plenty of results.
(blog)
(4,376 Views)
