03-07-2016
08:33 PM
- last edited on
05-06-2025
09:59 PM
by
Content Cleaner
Hi all,
I had been using myRIO 1900 to measure output from microphone that ranges from 0 to 5V (biased at 2.5V).
I was using one of the single ended Analog Input ports in MXP connector A or B to read the value.
Due to some reasons, i changed the microphone with an amplifier and when measured using oscilloscope and other DAQ devices, the output range from +5V to - 5V.
As the MXP can't read -ve voltage, i realised that I need to change the connection to MSP Connector C.
It's mentioned in the myRIO dataheet that we can measure differential analog input channles upto +/- 10 V.
Though there are some reference materials available, i don't completely understand how to read single ended output using differential input.
Should I use any op-amp's or just directly wire them?
Can anyone kindly explain me the differences and some reference on how to connect them!
Though i tried to read through this white paper, i felt completely lost 😞
Single ended output from micorphone and/or amplifier has 2 pins: Vout and GND
Different input has 3 pins: A+, A- and AGND
I had attached the screenshot of the OPAMP data sheet for your reference
Solved! Go to Solution.
03-08-2016 05:04 AM - edited 03-08-2016 05:05 AM
I believe you just need to connect your Vout to the +ve differential termination, the GND to the -ve terminal. (Briefly) A single-ended measurement is between the AI channel and AGND whereas a differential measurement is between the +ve and -ve terminal. A single ended measuring device is referenced to GND so that's where you're measuring the voltage from.
03-08-2016 10:18 AM
Thanks Sam_Sharp ![]()
Though i made the connection as if what you had mentioned in the post, the values read were very strange.
After seeing your post, i went back to my check my connections and verified my program to realise that i was using U16 data type FIFO to transfer the analog data from FPGA to myRIO. Once I changed it to I16, the program was working seamlessy.
