Academic Hardware Products (myDAQ, myRIO)
MyRIO undefined error or Error 8000
Hey guys,
I´m getting started with the myRIO-1900 and try to connect it with my car via X-CAN or OBD-II to collect and record data from my car.
I've installed Labview 2014, X-CAN, realtime module in my computer without any problem. And I have tested successfully the myRIO project under "Template Projects" which is the xyz motion thing and it worked.
However, when I connect myRIO-1900 with my car using OBD-II connector, powered by a car adapter, and launch "X-CAN for myRIO" under "sample project", there is a problem. When I click run, the error message pops out saying undefined error.
So here´s the Screenshot of it:
Any suggestions? Thanks.
(5,408 Views)
LichLich1,
On the download page for X-CAN it mentions that if you have technical support questions  you can contact Stratom at info@stratom.com.
http://www.ni.com/gate/gb/GB_EVALTLKTSTRATOM/US
I would try to contact them for support especially because this is an undefined error in their software.
(5,392 Views)
Did you managed to solve this problem? I am asking this because I encountered the same issue.
Thanks you for your response
(4,230 Views)
