‎11-11-2013 02:01 PM
My serial number worked for multisim but not for labview. I called support but they did not help. There only advice was to post a question here because I got it with my mydac.
Thank you
Solved! Go to Solution.
‎11-12-2013 07:54 AM
Hi there,
Welcome to the Discussion Forums! If you called an Applications Engineer and gave them your Serial Number and they said it is only for Multisim, then you need a different one for LabVIEW. Did you purchase LabVIEW along with Multisim and expected both of them to be under the same Serial Number?
If you want, you can send me a private message with your Serial Number and I can double check what you're entitled to activate with that. If you have another question you'd like help on, please let me know.
‎11-14-2013 07:27 AM
I got a cd with my mydac that has both Multisim and labview on it. However I only see one s/n. I do not have the S/N on me now but I will soon. When I called they only told me they could not help because it came with the mydac.
‎11-14-2013 09:31 AM
If you have an issue with your myDAQ, you can post it here. If you have an issue with activating a product such as LabVIEW or Multisim, you will be able to get phone support.
Which is the current issue you are having?
When you purchased your myDAQ, did you also purchase Multisim and LabVIEW with it? If not, most likely those discs are just for evalution.
‎11-14-2013 11:20 AM
some how. I have no idea how. I tried to load labview and it worked. I dont know why it wouldnt let me before but it now works. Thank you for the support!
‎11-14-2013 01:01 PM
Awesome. I'm glad you're up and running now.
