Academic Hardware Products (myDAQ, myRIO)
myrio digital channels always HIGH
Now that everything is fixed, the digital channels function properly when a VI is running. However, when the myRIO is powered but just sitting (not running a VI) the DIO channels are all HIGH. Is there a way to change this so they are LOW when no VI is running??
Message 11 of 13
(2,212 Views)
Accepted by topic author Zillion
Glad you got it sorted - I guess it was an installation problem then?
According to the documentation for the myRIO:
On the MXP connectors, each DIO line from 0 to 13 has a 40 kΩ pullup resistor to 3.3 V, and DIO lines 14 and 15 have 2.2 kΩ pullup resistors to 3.3 V. MSP connector C has eight DIO lines. Each MSP DIO line has a 40 kΩ pulldown resistor to ground.
You would need to either use the MSP connector C as that has lines that are pulled down, or use a stronger resistor on the other lines to cause it to float in the other direction (e.g. towards ground).
(blog)
Message 12 of 13
(2,204 Views)
Thanks!
Yep, the problem was the software installation. I had to uninstall it all and re-install.
Message 13 of 13
(2,188 Views)
