CANOpen and an NI-CAN card on a PC in slave mode
We have a PC with an NI-CAN card and this PC is a node in a CAN network that has to act as a slave. A master is sending NMT messages but how do I have to receive them? Our PC has to be put in the Operational State. Bottom line is that I have to send and receive PDO’s. We purchased the CANOpen Library recently but now I’m beginning to believe that it is of no use because it can only act as a master. Is this really true or am I missing something?
(4,176 Views)
Hi
yes you are right the Library does only support the master mode. In your case you could use the Frame API to create your own CANopen Slave API.
You need a Loop which takes care of the NMT handling and a second loop which waits for incoming PDO remote requests and answers them.
There are some requests within this forum regarding Frame API and CANopen.
DirkW
(4,165 Views)
first thing u should decide is 1 node will behave as slave only or master/slave configuration as in CANopen u can hav this two configuration. node will be brought up in to OPERATIONAL State by NMT itself by sending command.u need to prepare LLD 1st from whee u will get idea about different state of slave as well as NMT.
u need to download specification from CIA which is  standard all over to use for CANopen.
(4,110 Views)
