03-02-2006 10:03 AM
03-03-2006 09:07 AM
Hi max,
unfortunately it is up to CiA to update the test software to support the newer software and hardware, because they own it. Right now the package only supports 1.6 and 1.6 supports only series 1 hardware. We from NI have no chance to update the software by ourself.
DirkW
03-08-2006 03:56 AM
Hi max,
A mimimum version of NI-CAN 2.1.1 is required for using series 2 CAN hardware. You must use NI-CAN version 2.2 if possible.
Is there a previous driver installed?
Regards.
Omar S. NI
		03-08-2006
		02:51 PM
 - last edited on
		02-12-2025
		09:43 AM
 by
			Content Cleaner
Hi max 123456,
If you don’t need the Series 2 features and the second port of your PCI-CAN card, get the PCI-DNET card instead. NI-CAN 1.6 will detect the PCI-DNET card as a 1-port high-speed CAN card. Other that the different connector (the PCI-DNET card connects to the CAN bus via a 5-pin COMBICON connector instead of the DB-9) the PCI-DNET card work just like a Series 1 high-speed PCI-CAN card (1-port).
-B2k
03-14-2006 02:47 AM
03-14-2006 08:16 AM
