Displaying bus statistics
Hi
We are using NI 9853 CAN Controller and NI PXI 1031 and we want to show the bus statistics
as required which can be seen on the attachment, Is this provided by the tool or
we have to implement that manually?
Regards
Amit
(7,284 Views)
Have a look to this example. Perhaps it is a starting point, for calculating the statistics.
Here is the LINK
DirkW
Message Edited by DirkW on 09-18-2008 08:45 AM
(7,276 Views)
Hi
My application runs on PXI where i am having a seperate CAN slot. So is there any inbuilt functionality as in MAX which
monitors the bus on host for PXI as well?
Regards
Amit
(7,013 Views)
Hey Amit,
There is not bus monitor option on RT as you have on the host. So, if you have connected your PXI as a remote device, you would not be able to see the bus monitor.
I am not sure if there is any workaround for this. Let me search for it and get back to you.
Pavan
(6,999 Views)
Thanks that would really help us....
Regards
Amit Ahuja
(6,996 Views)
