Does anyone using CANcaseXL experience?
TroyK 已寫:
It is better that you look at the vxlapi.dll documentation and understand what is going on, but I added a CAN receive example to the community document anyway.
CAN Receive Example.vi added due to popular demand.
Hello , TroyK , I can use this vi work normally but I found some word I don't understan like.. "DLC"
Message 11 of 19
(4,485 Views)
http://en.wikipedia.org/wiki/CAN_bus
DLC = Data Length Code. Number of bytes of data (0–8 bytes)
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 12 of 19
(4,482 Views)
TroyK 已寫:
Thank you,, Your answer is really helpfulSmiley LOL
Message 13 of 19
(4,475 Views)
TroyK 已寫:
So , I guess the relationship is like as below right?
DLC       DATA
0000      0byte
0001      1byte
0010      2bytes
0011      3bytes
0100      4bytes
0101      5bytes
0110      6bytes
0111      7bytes
1000      8bytes
I have another question, Can "DLC=000" possibly?
Message 14 of 19
(4,461 Views)
Yes, DLC is 4 bits.
Standard CAN DLC 0-8, value = number of bytes.
b0000  d0  0bytes (Yes, you can have zero bytes for wake-up for example)
b0001  d1  1byte
b0010  d2  2bytes
b0011  d3  3bytes
b0100  d4  4bytes
b0101  d5  5bytes
b0110  d6  6bytes
b0111  d7  7bytes
b1000  d8  8bytes
In CAN-FD number of bytes above 8 is encoded:
b1001  d9   12bytes
b1010  d10  16bytes
b1011  d11  20bytes
b1100  d12  24bytes
b1101  d13  32bytes
b1110  d14  48bytes
b1111  d15  64bytes
Message 15 of 19
(4,455 Views)
TroyK 已寫:
Yes, DLC is 4 bits.
b0001  d1  1byte
b0010  d2  2bytes
b0011  d3  3bytes
b0100  d4  4bytes
b0101  d5  5bytes
b0110  d6  6bytes
b0111  d7  7bytes
b1000  d8  8bytes
b1001  d9   12bytes
b1010  d10  16bytes
b1011  d11  20bytes
b1100  d12  24bytes
b1101  d13  32bytes
b1110  d14  48bytes
b1111  d15  64bytes
I have this question is from "Data field"
I can not understand why 0..64 ,, Is not 0..63(8byte)?
Message 16 of 19
(4,450 Views)
DLC is a 4bit field used to specify how many bytes of data are contained in the CAN frame.
4 bits can have a value of 0-15.
For DLC values 0 to 8 the number of bytes is equal to the DLC value.
For DLC values 9 to 15 the number of bytes is determined by the table I listed before.
A standard CAN frame can have 0-8 bytes.
A CAN-FD frame can have 0-64 bytes. (BYTES! not BITS)
CAN-FD is new, prehaps I shouldn't have mentioned it.  A network will be either CAN-FD or CAN but not both.  You can't mix them on the same bus.
Message 17 of 19
(4,446 Views)
TroyK 已寫:
Thanks your explain,,,I think I just confused the index and length! Cat Very Happy
Message 18 of 19
(4,437 Views)
Update to my statement for accuracy accounting for emerging technology:
Actually you can mix CAN and CAN-FD if all the older CAN nodes are put to sleep in a partial networking scheme or the tranceivers they use are specially designed to filter out CAN-FD frames.
Message 19 of 19
(4,301 Views)
