Error 1074384864 [Invalid reference has been passed to a NI-XET session]
Dear all,
I receive an error when I try to transmit CAN frame using the bus monitor of NI-MAX. I am using NI-XNET 14.0 version.
Full error in the attachment below.
I am verifying why I cannot write messages on the CAN bus. I recieve messages, analyse, process and plot targets on a radar CAN device. But communication has been a bottleneck.
Any help is much appreciated.
Kind regards,
(8,698 Views)
It is strange you are seeing that error in MAX.  Have you tried rebooting?  It is a lame thing to try but I can't think of any other reason why the bus monitor wouldn't work.  That is the thing that should always work and then you build up from there.  I think you'll need help from someone at NI if a reboot doesn't fix it.
(8,683 Views)
Accepted by topic author Red43
It was strange but I have figured it out now. A couple of reboots didn't work but then it did.
I have translated write function to my code as well.
(8,681 Views)
