How many USB-8472s can I connect to the same computer
I have an application that would require connecting 4 USB-CAN devices to the same computer and control them all through LabWindows.  Does the driver facilitate this, or is it a one-at-a-time deal?
(6,219 Views)
No, you can have as many USB CAN devices as you can plug in to your PC. If you use a Hub, don't forget to add a power supply.
DirkW
(6,204 Views)
