Home
Community
Discussion Forums
Additional NI Product Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I cannot open the can communication in Windows 2000 as I could using the same application in Window 98, I am using the 1.42 version driver
steverink
Member
04-05-2001
10:42 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
0
Kudos
Message
1
of 2
(4,841 Views)
Reply
Re: I cannot open the can communication in Windows 2000 as I could using the same application in Window 98, I am using the 1.42 version driver
bsat
Member
04-09-2001
05:09 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
What is the problem you are seeing with the NI CAN function calls? What does your application do? Are you using a Low speed/high /dual speed CAN card?
What errors are you seeing?
0
Kudos
Message
2
of 2
(4,841 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
