I cannot open the can communication in Windows 2000 as I could using the same application in Window 98, I am using the 1.42 version driver
What is the problem you are seeing with the NI CAN function calls? What does your application do? Are you using a Low speed/high /dual speed CAN card?
What errors are you seeing?
(4,881 Views)
